Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Kinetic Mechanisms and Arrhenius Equation Parameters in ANSYS Fluent › Reply To: Kinetic Mechanisms and Arrhenius Equation Parameters in ANSYS Fluent
ghislain_madiot
Hi Vijay,
Here the information you asked:
  • I use Finit Rate / No TCI with the Explicit source for chemistry solver.
  • Density formulation in the initial case is ideal gas
  • Rate exposure is equal to 1
  • The initial time step in the plot were 10e-5 which corresponds to the Chemkin methodology, but I noticed the same behavior with lower time step like 10e-7. I quick run a case with 10e-8 same result.
  • Scheme used is Coupled, however I ran the same case with SIMPLEC and PISO and obtained even higher value of mass
I put the screenshots for the differents menu
Perhaps, it might be usefull if I share the model or the setting file with you.
Ghislain
