Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Installation Error Running VM Parallels Evaluation Licence › Reply To: Installation Error Running VM Parallels Evaluation Licence
May 13, 2024 at 11:19 am
Mrunali Barde
Hello Mo,
Can you launch the Ansys licensing setting tool as administrator and then add server details to check if that regenerates ansyslmd.ini file?
With that, can you try using the IP address instead of hostname/servername in the Ansys licensing settings and check if that resolves the -96 error?
I hope this helps,
Mrunali.
