Ansys Learning Forum Forums Discuss Simulation Electronics Q3D parametric sweep field calculator Reply To: Q3D parametric sweep field calculator
anja.ulrich
Hey Praneeth,
Thanks for your fast reply! This already helped me a lot! I had the eoption save fields and mesh enabled! However in the fields calculator option I only see that I can chose one sweep solution. Am I right that it is not possible to use the fields calculator to access all sweeps at once?
I tried the recording and I get now the right commands to calculate my parmameters however how can I read out the evaluated value to the script as a parameter? so save the the CalcEval command in a variable? I can see it is read out in the field calculator window but the CalcEval returns NONE according to the programming manual...
Best,
Anja
