Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ANSYS Topology optimization – Controlling the margin of material removed. › Reply To: ANSYS Topology optimization – Controlling the margin of material removed.
May 11, 2024 at 11:09 am
Aswin Thomas
Thanks for the reply. I have tried the elemental density. It is possible to play with the amount of material retained after the solution if I use elemental density. But that is not what I want. I want the solution to be in a way that the margin of material removed or retained (in the range of 0 to 1) should be controllable. Is there any way for that?
