Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to set simulation conditions for coplanar microstrip line CPS (or differenti › Reply To: How to set simulation conditions for coplanar microstrip line CPS (or differenti
dushyant.marathe
Thanks Kirthika for answering some of the queries on Waveport.
There was another query about de-embedding.
Deembedding in HFSS refers to the process of adding or subtracting a transmission line to modify the S-parameters at the ports. This technique is used in situations where you want to shift the reference plane of the S-matrix for any port by adding or subtracting a length of lossless transmission line. In HFSS, deembedding is allowed only for wave ports and Floquet ports. I would suggest refereing HFSS help PDF for more information.
