Ansys Learning Forum Forums Discuss Simulation General Mechanical Convert Local Coordinate to Global – Automated Reply To: Convert Local Coordinate to Global – Automated
mjmiddle
Have you defined a local coordinate system on a path definition?
Or on a linearized result?
Are you just trying to get one point (first point) in the global coordinates, or all the locations along the path in a result?
If you export the data from a result scoped to a path, the XYZ will be in global coordinates. This export command could be done by script.
