Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Successful explicit analysis › Reply To: Successful explicit analysis
May 10, 2024 at 5:02 pm
Hi
I ran my same model without Load_gravity_part_set. And now the energy plot seems reasonable as mentoned by you.Â
SO, using Load_gravity_part_set applied to seven course parts of tank cuses the issues. I defined it loke below:
Do you think I should define it as Load_body_z instead of Load_gravity_part_set? I mean why the Load_gravity_part_set definition makes the model behaving so weird since the energy plots not good. Thanks.
