Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Poynting vector in Ansys HFSS › Reply To: Poynting vector in Ansys HFSS
Faezeh Tork Ladani
The simulation most likely needs denser mesh for more accurate field calculator operations. You can start with a dense mesh by doing mesh operations and/or decrease max delta S and enforce more adaptive passes. Also, you can decrease the length of the waveguide as it has a uniform cross section.
