Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Unusual liquid velocity and bubble size distribution by using PBM › Reply To: Unusual liquid velocity and bubble size distribution by using PBM
It's unlikely that you'll get zero liquid in the head space, and it's that tiny volume fraction that gives the velocity field you're seeing. One trick is to use a Custom Field Function (in the User Defined tab) of vol_frac_liquid x velocity as that'll mostly eliminate the odd result. Clip planes are another option.
