Ansys Learning Forum Forums Discuss Simulation Fluids Air heat insulation Reply To: Air heat insulation
CFD will work in steady state, and will handle both the flow in the cavity and heat transfer in the solids. Have a look in Learning > Fluids to see what's possible.
I have no idea re the geometry and don't know if that's a geometry option you've picked or something in Mechanical.Â
