Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Air heat insulation › Reply To: Air heat insulation
May 8, 2024 at 12:29 pm
I suspect you need to use fluid elements then, but as the fluids team don't use Mechanical you may find asking in the appropriate space to be more useful.Â
