Ansys Learning Forum Forums Discuss Simulation General Mechanical Non Linear Analysis Taking Too Long Due to Bisection Reply To: Non Linear Analysis Taking Too Long Due to Bisection
Aniket Chavan
Have you checked the displacement convergence as well? With the warning 'plasticity algorithm did not converge ...' the program will bisect the solution by reducing the load increment. If the bisection proceeds without problem the solution continues. This means that ANSYS does not store the results when the plasticity algorithm has not converged for integration points. Hence this means that as long as you can get a converged solution the results should be OK. (i.e. if you get nonconvergence that means incomplete results are present. However, any converged results should be fine.)
-Aniket
Forum Rules & Guidelines
