Ansys Learning Forum Forums Discuss Simulation Fluids Transfer from Discovery to Fluent Reply To: Transfer from Discovery to Fluent
Having had it checked here the transfer process takes several minutes with an example case so you may just need to leave it longer. Depending on the model size that could be a lot longer. I typically go geometry>Fluent Meshing>Solver but that's also because most of the physics I'm looking at isn't (yet) in Discovery.Â
