Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys Mechanical freezes on opening Reply To: Ansys Mechanical freezes on opening
Jonas Holzrichter
I did everything and now it works. Thank you very much!
Unfortunately, I did everything one after the other and cannot say exactly which tip finally solved the problem, but Mechanical started without errors and showed me my imported geometry. I hope that the problem is now completely solved. If the error occurs again, I will report back.
Thank you very much for the tips and the final solution!
