Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error opening sample files in Chemkin › Reply To: Error opening sample files in Chemkin
HI Ghazal:
It looks like your Chemkin sample file could not be loaded - maybe because it is not present or because Chemkin isn't configured properly. I would review the instructions in "Verifying your Installation" in Chapter 1.7 of the Chemkin Getting Started Guide
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/chemkin_gs/i27393.html
If the file C:\Users\User\chemkin\samples2021R2\pre-mixed_burner__burner_stabilized.ckprj exists, try moving it to a local directory and see if it will load from there. This will rule out any problems with Java, which is required for Chemkin to run.
Best Regards,
Judy
