Ansys Learning Forum Forums Installation and Licensing Ansys Products Hidding areas during meshing in multiple volume components modelMechanical APDL Reply To: Hidding areas during meshing in multiple volume components modelMechanical APDL
danielshaw
You can activate/deactivate areas by selecting and unselecting them using the ASEL command.  ASEL,S selects areas from the full model.  ASEL,R reselects areas from the currently active set.  If you select a subset of areas, subequent meshing operations will only occur on the active set.
