Ansys Learning Forum Forums Discuss Simulation General Mechanical ANSYS WORKBENCH LS DYNA ELEMENT CONTROL Reply To: ANSYS WORKBENCH LS DYNA ELEMENT CONTROL
erik.kostson
Hi
Element control is only for ANSYS MAPDL Solver not LS-Dyna, so hence why it is not there. LS-Dyna have different elements and concepts.
See below for a summary.
See this doc. below for element formulations – by default it uses elform=1 (see doc. below), because we mesh with Explicit physics setting and linear element order (see mesh details in LS-Dyna workbench).
https://www.dynamore.de/de/download/papers/forum11/entwicklerforum-2011/erhart.pdf
You can change the elform/section of a solid via the main menu and LS-Dyna Pre Tab, then Part, and choose Section.
See here for more info:
4.6. Part Setup (ansys.com)
(see here how to open the above help link: /forum/forums/topic/how-to-access-the-ansys-online-help/#:~:text=Open%20Ansys%20Workbench%20(or%20any,A%20browser%20window%20will%20open.)
Finally you can check the section/elform by opening (say with notepad or in LSPrePost) the input.k file (LS-Dyna input file in Solution folder), and look for the keyword: *SECTION_SOLID
Also see more details about this and elform in the LS-Dyna manual Volume I, II and III.
The above covers all about the different elforms and how to choose and see them. For more information about the elforms used in Ls-Dyna or any other questions, use the dedicated LS-Dyna forum. Closing it here and as we said contnue under the appropriate LS-Dyna channel .
(Under My Channels, and LS-Dyna)
All the best
Erik
