Ansys Learning Forum Forums Discuss Simulation Fluids Multiple component coordinate systems to fluent for material properties Reply To: Multiple component coordinate systems to fluent for material properties
CL86
It works!
Well, at least that issue works. Results show the expected behaviour.
In essence for further readers: one material per component, with the cyl-orthotropic coordinates in the material properties. Even if all the components are the same - the material property defines the coordinate system for the assembly.
Cheers Rob, much appreciated!
