Ansys Learning Forum Forums Discuss Simulation Fluids High-Velocity Air Flow Through Small Nozzle into Large Tank Reply To: High-Velocity Air Flow Through Small Nozzle into Large Tank
Possibly. You may then need to patch the region above the nozzle to the correct pressure.  Fluent needs to know the upstream pressure to get the density right, which then alters the flow field.
