Ansys Learning Forum Forums Discuss Simulation General Mechanical nodal moment or force reaction in a tube with harmonic excitation Reply To: nodal moment or force reaction in a tube with harmonic excitation
dlooman
A common, pretty easy way is to select a set of nodes at a cross-section and the elements on only one side of those nodes.  Then fsum, possibly in conjunction with spoint will give you the moment at that location.
