Ansys Learning Forum › Forums › Discuss Simulation › Fluids › High-Velocity Air Flow Through Small Nozzle into Large Tank › Reply To: High-Velocity Air Flow Through Small Nozzle into Large Tank
lantonini
I'm considering pressures between 20'000 Pa and 140'000 Pa. But, since my inlet area is grater than the nozzle one, the flow is subsonic at the inlet. In this condition, the simulations should not be affected by the value of Supersonic/Initial Gauge Pressure, right?
