Ansys Learning Forum Forums Discuss Simulation Fluids Multiple component coordinate systems to fluent for material properties Reply To: Multiple component coordinate systems to fluent for material properties
CL86
Hi Rob,
Thanks for your continued support - much appreciated!
So what I have been doing is defining the material once, then looping through the cell zones assigning the material, and then (wongly) using the cell rotational zone coordinates, assuming that that aligned the cyl-orthotropic axis to the cell zone.
What I need to do is loop through defining the materials with the same coordinates I previously used, and then another loop only assigning the material properties but leaving the cell rotational zone coordinates alone.
OK, cool, thanks Rob!
