Ansys Learning Forum Forums Discuss Simulation Fluids Multiple component coordinate systems to fluent for material properties Reply To: Multiple component coordinate systems to fluent for material properties
CL86
OK, I set the material properties as above – I have defined one material:
I have then tried to assign that material to each component using a journal file, stating the axis of rotation about which I would like the material to orient. The script has indeed applied the material and altered the coordinates for each cell:
However, the results clearly show that this hasn’t worked – it would appear that every cylinder has the cylindrical axis for thermal conductivity centred about the global origin, rather than around the coordinates specified in the solid zone rotation-axis origin.
Not quite sure what it is I am doing wrong – the only thing I can think of is that I have to create a new, independent material for every single cylinder and then alter the coordinates in the cyl-orthotropic panel – but this doesn’t really feel sensible?
