Ansys Learning Forum Forums Installation and Licensing Ansys Products Impact Analysis using Explicit Dynamics Reply To: Impact Analysis using Explicit Dynamics
be21b028
1. I did apply the velocity of 15m/s using initial conditions.
2. Energy Summary was also plotted through solution output, but there was no change obtained in the graph.
3. Material rubber was used as the default material existing in Ansys library. How should I use hyperelastic material model?
4. Time step was calculated according to the materials used. The earlier simulations were made without providing the time step.
We have already tried doing these but still didn't get desired results. How could we check if the impact analysis that we did is accurate or not?
