Ansys Learning Forum Forums Discuss Simulation Fluids Transient Porous Media Combustion Reply To: Transient Porous Media Combustion
Ren
If you just wanted to have a mixture that will be combustible, then you can try to increase the air mass flow rate (not velocity) to get an air-to-fuel ratio of, say, 19. The easiest way of doing this is to change the inlet boundaries to mass-flow-inlet type so that you can enter mass flow rate (MFR) values directly. Currently, you have
fuel MFR = 1.832E-5 kg/s, so you can try
air MFR = 1.832E-5 * 19 = 3.4808E-4 kg/s
