Ansys Learning Forum Forums Discuss Simulation Fluids Changing the geometry in existing case Reply To: Changing the geometry in existing case
Oscar Barthel
i tried to read in the new mesh and deleted every report definition beforehand but i still got the same errors:
pop up window:
   zone-surface: invalid thread[2]
console:
   Error at host: zone-surface: invalid thread[2]
   Error at Node 0: zone-surface: invalid thread[2]
   Error: zone-surface: invalid thread[2]
   Error Object: #f
i also tried to only read in a settings file in the new case but this still led to the same errors. I even tried to use a different new geometry which had the same amount of internal openings as the old geometry from which i extracted the settings file but it still didnt work and produces the same error as before. Do you have any idea what could solve this error?
By the way thank you very much for your time, i really appreciate it :)
