Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Transient Porous Media Combustion › Reply To: Transient Porous Media Combustion
Ren
You did not show me the mass flow rates but the mean mixture fraction contour indicates that the mixture is too rich in PM2 to burn, i.e., the mixture is outside of its flammability range. Please double check your boundary conditions.
FYI, you can report the mass flow rates of all or selected boundaries using
Results->Reports->Fluxes, select "Mass Flow Rate"
