Ansys Learning Forum Forums Discuss Simulation LS Dyna Verifying my result from LS DYNA Reply To: Verifying my result from LS DYNA
ashish.khemka
This formula is for static load acting at the center for both ends fixed. You should expect a higher deformation (and the formula should be a different one) as the object is moving with a velocity.
Ashish Khemka
