Ansys Learning Forum › Forums › Discuss Simulation › Fluids › High-Velocity Air Flow Through Small Nozzle into Large Tank › Reply To: High-Velocity Air Flow Through Small Nozzle into Large Tank
Thank you for showing interest in my analysis.
The choice of the turbulence model was guided by a literature review, where I found that k-epsilon RNG and k-omega SST models were commonly used for similar applications.
Should I use a different model?
My system consists of a single phase, air, and I am attaching an image showing the detail of the mesh, representing the Velocity Magnitude color map.
I'm using a hexcore mesh considering 8 boundary layers.
Specifically, in the image, I have zoomed in on the area where the air is moving from the inlet tube (at the top with flow from right to left) to the tank (at the bottom).
The flow direction is indicated by the arrows.
