Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Particle volume on a surface › Reply To: Particle volume on a surface
Lucas Bertollo Baggio
Yes, either on Particles or in a child User Process Properties tab, plot (in a Time Plot, for example) Coordinate : Y (or X or Z, depending on what is your 'height' axis) by Average.
Besides using a Time Plot, you can go to Rocky Menu | Tools and enable Expressions/Variables, then drag the property you want to analyze on the Output tab and filter properly.
