Ansys Learning Forum › Forums › Discuss Simulation › Fluids › BCs for buoyant flow with outlet parallel to gravity vector › Reply To: BCs for buoyant flow with outlet parallel to gravity vector
April 24, 2024 at 1:30 pm
Ren
Could you please try the following first:
- Define a monitor for max temperture in the domain, run the existing calculation further to check if the max T is still changing.
- Activate the DO radiation model, set the absorption coefficient method to wsggm-domain-based for the mixture material.
