Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Using Dense Discrete Phase Model Injection Type › Reply To: Using Dense Discrete Phase Model Injection Type
April 24, 2024 at 12:45 pm
You're tracking parcels. So, 42 parcels are tracked each holding 0.1146/42 kg/s. Each parcel trajectory is calculated based on the diameter & material property you set in the injection. Read up on Parcel Theory for a more complete explanation.
In Fluent the reports/settings for particle should have been labelled as parcel in most instances. As the terms were muddled up in about v3 there's not much chance of them being corrected.
