Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to track deformation of a face/line of a solid in a mechanical simulation? › Reply To: How to track deformation of a face/line of a solid in a mechanical simulation?
April 24, 2024 at 8:11 am
If you right-click and export to text, it should export the nodal result at the current time step. You can change the time, reevaluate the result, and export the result. Alternatively, you can insert results for all required time steps and use something like this to export using scripting :https://catalog.ansys.com/product/5b3bc6857a2f9a5c90d32e7f/multi-object-exporÂ
-Aniket
