Ansys Learning Forum Forums Discuss Simulation Fluids Changing the geometry in existing case Reply To: Changing the geometry in existing case
Oscar Barthel
yes, the geometry change alters every surrounding fluid zone. Reading the new mesh in to the existing case per se works altough i get some notification that surfaces for report definitions cant be found. Initializing also works but when i try to patch one of the fluid zones i get about 20 times the same error:
pop up window:
   zone-surface: invalid thread[2]
console:
   Error at host: zone-surface: invalid thread[2]
   Error at Node 0: zone-surface: invalid thread[2]
   Error: zone-surface: invalid thread[2]
   Error Object: #f
