Ansys Learning Forum › Forums › Discuss Simulation › Fluids › BCs for buoyant flow with outlet parallel to gravity vector › Reply To: BCs for buoyant flow with outlet parallel to gravity vector
April 22, 2024 at 3:20 pm
Hi Ren - Thanks for the note; the Integration Parameters are below. I have not used ISAT before this project with Fluent, and the settings there are default. Do you think I should reduce the ISAT tolerance?
The fuel is a mix of 65% H2, 35% NH3, molar basis, and I'm using a mechanism from Stagni et al, 2020, which is currently one of the better ones available for predicting N-H-O reactions in ammonia combustion (31 N-H-O species, 203 reactions, https://pubs.rsc.org/en/content/articlelanding/2020/re/c9re00429g ).
