Ansys Learning Forum › Forums › Discuss Simulation › Fluids › BCs for buoyant flow with outlet parallel to gravity vector › Reply To: BCs for buoyant flow with outlet parallel to gravity vector
April 22, 2024 at 2:53 pm
Hi, Daniel,
The setup in the Species Model dialog box look fine. Could you also show me the Integration Parameters dialog box? What is the fuel? What chemical mechanism is used?Â
