Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Analyzing elout for 2 solid sets in Binout › Reply To: Analyzing elout for 2 solid sets in Binout
April 19, 2024 at 2:53 pm
gdickey2
Hello Reno,
Thanks for this. The problem I have is that the model I'm using, the elements are not ordered in a sequential pattern. That is, they jump numbers (e.g., 1470089, 1470112, etc.). I played around quite a bit to see if I could sort this, but there are thousands (~4000) in each set. It's likely faster for me to just run 2 separate simulations with the separate sets. Unless there is something else I can do that could potentially deal with this problem.
Thank you,
Grant
