Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Multiple component coordinate systems to fluent for material properties › Reply To: Multiple component coordinate systems to fluent for material properties
I think you set the material via
So it's material dependent. However, once you've set one material up the TUI comes in to play. Click into the Fluent Console, and type
/define/materials
Then follow the prompts. This will give you the command syntax. It's then a case of combining the commands with the coordinates & material labels from SpaceClaim etc to build a journal file. Sounds complex, it's very simple but you need to exercise care.
There's also a solid zone option - Material Orientation - but I don't that's what you need here.
