Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Update enclosure with parametric analysis › Reply To: Update enclosure with parametric analysis
Hello Antonio,Â
You can use History tracking for doing this. In History tracking each operation you perform is recording a step and you can make changes to the settings and parameters, and play back the operations to recreate the workflow.Â
For example, if you see the heat sink case, I have parametrized the height of heat sink and than created an enclosure. Than using the height as parameters, I have created a variations and run the case. With History tracking as the hieght updates, the next step it does it creates the enclosure according that change and it updates automatically.Â
Let me know if you have any further questions. Refer this History Tracking in ANSYS Discovery - Ansys Knowledge for more information.Â
Regards,Â
Devendra
