Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Contour of Custom Field Function and expression is quite different in Fluent › Reply To: Contour of Custom Field Function and expression is quite different in Fluent
Hi Rob,
The images and ranges become same after I deselected node values.
1.Is it because the interpolation method different for Custom Field Function and Expression?Â
2. I use Custom Field Function to define new variables because I just don't want to show unit under colormap. Are there any ways not to display unit under the colormap except for using Custom Field Function in Fluent?Â
3. I want to make each words of  Custom Field Function name started with capital letter, but I find that the letter of new Custom Field Function name cannot be capitalized. Can I make it in some ways?
Best regars.
LEE
