Ansys Learning Forum Forums Discuss Simulation General Mechanical Analysis Settings won’t Verify in Transient Analysis Reply To: Analysis Settings won’t Verify in Transient Analysis
Aneesah Nabi
Thank you, I'll use less steps and see how it works. When I was inputting my values as above the solver wouldn't run and the settings had a question mark in front. However, I believe that is partially because of what you mentioned where I haven't input for all 230 steps. No worries, I'll reduce the steps and see how it works out. Thank you!
