Ansys Learning Forum Forums Discuss Simulation Optics Workbench + speos 2024R1 Reply To: Workbench + speos 2024R1
vision
OK, first of all thank you very much for your reply.
I did notice that Spaceclaim supports scdocx files and can open them normally.
I thought I’d describe the process I’m going through to build the project so that you can understand the problem I’m having
1. open workbench, drag in Speos analysis system
2. import the xx.scdocx file in Geometry and it opens fine (this step is normal)
3. since the model is generated by script control, I need to double click on Geometry to open the model to read the script parameters to form a parameter set, but at this step “Geometry” changes from .scdocx to .scdoc. if I replace the model with .scdocx again, the parameter set will disappear.
4. Run Simulation Task, prompted for file conversion.
What can be done in step 3 to avoid changing the .scdocx file format to .scdoc? Or is there another way to import the script parameters without opening the file?
