Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Error while using Ansys Maxwell and Icepak Two-Way Coupling › Reply To: Error while using Ansys Maxwell and Icepak Two-Way Coupling
Marta Åšciubak
Hi
I set everything up this way, but I cannot get a solution. Even generating an accurate mesh in Icepak is a problem. I wonder if it is a problem of complex geometry.
I have written about it here:
/forum/forums/topic/high-voltage-cable-in-maxwell-3d/
I don't know if it is reasonable to model in 3D or do the analysis in 2D combined with Fluent? I'm not sure if in Fluent the analysis will work because I don't know if it's a problem with a slow computer or my model.
