Ansys Learning Forum Forums Discuss Simulation Electronics Error while using Ansys Maxwell and Icepak Two-Way Coupling Reply To: Error while using Ansys Maxwell and Icepak Two-Way Coupling
Flaming
Hi Marta,
please execute Validate in the Simulation Tab to ensure this design can pass validation check.
Simulate source design as needed is when you modify the source design and you want an updated source design
solution to be linked to the target design.
The possible reason is that in Maxwell, you must enable Include Temperature
Dependence and Enable Feedback in the Temperature of Objects dialog box,
which you can open by right-clicking the design and selecting Set Object
Temperature.
Best regards,
Joey
