Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Transonic Drag Under Predicted significantly › Reply To: Transonic Drag Under Predicted significantly
I'm only permitted to comment on what I can see in the thread and use "public knowledge", hence wanting some images.   Pressure, velocity & Mach Number contours will help. We're looking to see why you're not getting the results you expect, so any clues are helpful.
