Ansys Learning Forum Forums Discuss Simulation Fluids Transonic Drag Under Predicted significantly Reply To: Transonic Drag Under Predicted significantly
TJ Abraham
What pictures would be benefitcial for helping figure this out? I went through all of the training materials already in the learning hub and online and this setup should be very similar to that seen in those trainings.  When we discuss the mesh what is it you are looking for other than aspect ratio, quality, and skewness?  If those are all good it should be fine correct? Even if the mesh isn't hilght resolved it should be still get results in the expected ball park correct?  The geometry form SpaceClaim is in m, the mesh is read in m, and then all units in fluent are metric.  Im willing to go through pictures and contours to assist as needed just let me know what is of benefit.  Is it possible to set up a video chat?
