Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Transonic Drag Under Predicted significantly › Reply To: Transonic Drag Under Predicted significantly
Without images I'm guessing, but as there are a lot of similar cases being solved I'm fairly confident in the solver. Which then comes back to mesh, set up and post processing; and pictures.
Check the various Learning courses re the speed and solver - it's not my field but the 2-3M is in the training materials.
