Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Transonic Drag Under Predicted significantly › Reply To: Transonic Drag Under Predicted significantly
April 12, 2024 at 3:19 pm
Okay I found it. I went through the tutorial. My simulation is the same excpet it is a density based solver since we are above mach 1, compressability affects are on if we are running a turbulence model and I set my pressures in the farfield BC instead of in the operating pressures. Any other thoughts? I would love to figure out the problem here. Thanks!
