Ansys Learning Forum Forums Discuss Simulation Fluids Transonic Drag Under Predicted significantly Reply To: Transonic Drag Under Predicted significantly
TJ Abraham
Mesh quality all check out.  Attached is a zoomed out picture of the mesh.  This is has 7 million cells with y+ around 200.  As described above reference values are as follows:
Area: planform area of aircraft, Density: fluent calculated via pressure farfield BC, Enthalpy: pressure farfield, Length: from aircraft geometry, Pressure: this is static pressure from the pressure farfield calculated from atmosphere tables, Temperature: pressure farfield, Velocity: pressure farfeild, Ratio of Specific heat: default, yplus for heat transfer: default.
Any thoughts on that reference values or the mesh? I realize the mesh isn't perfect but it should be good enough to at least be within an order of magnitude right?  Regarding the NACA airfoil help where is that located?
