Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Export temperature data with Python code object › Reply To: Export temperature data with Python code object
erik.kostson
Hi
See this post that does that – instead of using ExportImage() method just change it to ExportToTextFile()
https://discuss.ansys.com/discussion/comment/2042#Comment_2042?utm_source=community-search&utm_medium=organic-search&utm_term=export+and+python+code
Also this post does that, but instead of ExportImage again use ExportToTextFile - use the code in a Python code object (after post).
https://discuss.ansys.com/discussion/2161/insert-results-and-export-image-and-animation?utm_source=community-search&utm_medium=organic-search&utm_term=Export+and+image
All the best
Erik
